dodge_guy
Apr 24, 2021Explorer II
noteven wrote:curt12914 wrote:dodge guy wrote:
Fords of that year have separate fuses for trailer taillight, left and right brake/turn lights.
Correct answer.
Update - closest answer ^ - but not any of the 3 - 15 amp fuses for each turn signal circuit or the brake circuit...
Not any of the 3 relays...
Not any kind of “module”...
There is also a 25 amp fuse in the under hood power center that fuses all three relays and all 3 fuses in the other fuse box / body module... it was blown.
Simple enough system once you find the info.
It’s in the owner manual the previous owner “lost” that I have been too lazy to replace...
Young tech at the dealership walked me through it in 5 minutes. He recommended a owner manual cause Ford fuse boxes are numbered not labelled.
Signed
A bit less confused by Fords
Glad you got it figured out. Yes, Fords fuse boxes are ridiculous. However Mopar is going the same route, although some are still numbered with the description. Also good to know that there are younger guys willing to go the extra mile for customer service.
