Mike134 wrote:
I think what people fail to notice is how much payload is used up on a F250 diesel because of the weight. The Gas F150 with HD payload package will have a larger payload than a 250 diesel and cost you about $12,000 less. For those non-believers experiment on the Ford build and price site. Now if you get a Gas 250 or diesel 350 you've moved up in towing capacity.
What MOST folks are missing is you DON'T "need" F150 Eco.
F250 with 6.2 is actually a much better choice overall for LONGEVITY when it comes to towing or hauling HEAVY LOADS for long periods of time than pushing limits with the lighter built F150 Eco.
When you get into the F250 and higher line, Ford has DERATED the engine and transmission in order to offer a higher MTBF (Mean Time Between Failure).
OP also does not "need" Diesel either which is why I suggested F250 with 6.2 instead of the Eco F150 with max Tow/Payload.
Yes, you won't get head snapping high speed hole shots with the 6.2 but that is not the point of going that route, the point is getting a much more robust long living vehicle that is more suited for the task of heavy or hard use for extended periods of time.
I once had a F150 Heavy half, all was good when I used it for grocery getting on very smooth roads.. When I started towing and put it on less than steller roads it fell flat with constant repair bills.. Rebuilt suspension twice in 140K miles, multiple brake refreshes (like clockwork at 40K miles)..
Replaced the heavy half with F250 Super duty in 2003, that truck was a vast improvement, ball joints at 175K miles no other suspension parts when I sold it at 240K miles.. Brakes well past 120K miles at a time.. I found I spent a lot less of my time working and replacing parts on that truck..
Folks believe you need a Diesel or a turbo boosted V6 to haul a potato chip, you don't, really.. Folks often gravitate to those because they WANT the prestige of saying they have it..
Yes, a plain NA Gas engine does not elicit visions of excitement or boost ones testosterone but Ford HAS done a very good job at making the 6.2 a very dependable and capable engine..
If you want a bit more grunt then perhaps consider the 7.3 Gas engine. But in reality, with the OPs load, a nicely equipped F250 with 6.2 will be a very good match for their trailer.
I have had no issues hauling 6500 lb TT loaded, have also loaded up my 18ft 10K flatbed trailer to the max of 10K and still have a lot of throttle left on 11% grades..
On edit..
For those who doubt me about F250 cost, here is my purchase documentation.. That is for a 2020 F250 Value XLT package, 4x2 Super cab short bed 6.2 gas 3.73 Electronic locking axle. I do not need or want the goofy leaky sun roof, nor do I need or want the heated/cooled leather seats (had a vehicle that came with leather seats, those seats were shot after 100K miles, won't do that again).
That price includes taxes, title and even cost of extended warranty and the bottom line is all in out the door cost to me.
