MFL
Mar 17, 2023Nomad II
Steve..after watching a Ford IBC install video, that is what I'd do. It looks like you need to do same disassembly, no matter which controller you choose. The aftermarket would be more work, needing some easy wire splicing, and drilling to mount to dash.
The OEM Ford connects direct to waiting plug. It does require the flash to activate, which may require a more savvy geek than me?? Any shop that has done this installation flash, could do yours as well. You may feel confident to do it yourself, using your own puter.
This is the video I watched, which was a qualified Ford tech, used to doing this install. https://www.youtube.com/watch?v=2IPGOFKehzk
Hope this helps,
Jerry
Hope this helps,
Jerry
