MFL
Mar 17, 2023Nomad II
Groover wrote:
The factory controller has the ability to access vehicle stability information and take steps to control an unstable trailer. That could be a life saver.
You need to be aware that the factor controller (at least in my 2016) model turns off the brakes below about 3mph, presumably to prevent burning up the brake actuators. There will be times that you don't want that to happen and you should keep a hand on the manual override. Example: coming down a steep gravel drive and trying to make a sharp turn onto a gravel road. I nearly got pushed off the side of a mountain once. It took me a while to figure out why. Any stop on a steep hill while towing heavy can be a challenge. In my case I am towing a trailer about twice as heavy as the truck.
Good info, concerning the OEM IBC no longer braking as you approach a full stop. I do think mine stops braking at more like 6-8 mph, rather than 3 mph. Good that the OP understands this, does not think his is not working correctly.
I also use the manual levers at times, slowing to stop, just saves a little on truck brakes, but not truly necessary, especially with trailers under 10K.
Jerry
