OH48Lt
Jan 12, 2014Explorer
If it had the HD package, would it have P rated tires? Should be LT tires, I would think. While the F150 Eco would have no problem with that combo as far as power, frame, and brakes, it would be a little light in the tires, suspension, and maybe rear axle weight rating. If its the 5.5' bed, forget it. That short wheelbase with that trailer would be handful in good crosswinds. If its the 6.5' bed, put some Timbrens on it and check into LT tires. Those P rated tires have way too much sidewall flex. The only problem there might be the TPMS units might need replaced also due to the higher tire pressures you will be using. A local tire shop told me that I couldn't go from P tires to LT tires due to the TPMS parameters programmed into the computer, even if I changed the sending units on each wheel. Not sure if I believe that or not.
44,026 PostsLatest Activity: Mar 03, 2025
