Question: are we sure that the Ford integrated sway control applies the trailer brakes in a sway event ? The following is taken from the 2011 Ford manual:
"When the system detects the trailer yawing in one direction, it applies selective brake pressure on the tow vehicle’s opposite side – called asymmetric braking. This creates counter-moments to the forces applied on the vehicle from the trailer, dampens the yaw motion and helps to reduce the sway"
Sounds to me like it is only using the truck brakes. The document goes on to mention that it reduces engine power as well.
http://media.ford.com/images/10031/Trailer_Sway_Control_SuperDuty.pdf
