rpodcamper wrote:
I can't seem to post images, but the door tag from the Odyssey has a GVWR of 6018 lbs and a GAWR rear 3197lbs and the sticker I found from a 2017 F150 shows a GVWR of 6250 and a GAWR Rear 3,300lbs. There is not as much as much difference as most people would think.
Overhang ratios are similar too, and center of balance is lower and the 4 wheel independent suspension gives it a significantly wider effective track (more stable). None of these observations on capability are going to to affect emotional responses, cause it's not a truck.
