rpodcamper's avatar
rpodcamper
Ford F150 VS Honda Odyssey
Hi Everyone,
This is my first post here.
Why is a Ford f150 so much better than my Honda Odyssey for towing a trailer. Both vehicles have about the same width, the GVWR is about the same for both. The Ford is about 4” longer ( that will help some). The Fords 3.5 (non ecoboost) has only about 15% more horsepower and 13ft lbs more torque. The Odyssey has 4 wheel disc brakes that are 12.3” (front) only slightly smaller than the ford. I know the ford will have stiffer suspension and that will help with stability and load capacity. The Odyssey has a 5 speed trans and the Ford has a 6 speed ( that will help some). Is there really that much of a difference between the vehicles.
My trailer has a GVWR of 3700lbs. I don't really want to debate the suitability of the Odyssey because I have it set-up for towing and we tow our trailer almost dry to keep everything under capacity and most importantly, I am replacing it with a proper TV.
Thanks in advance.
  • The F150 is so much better but I don't want to debate the Odyssey because it is set up for towing. Honda doesn't want to debate it either....tow limit 3,500 pounds. Couldn't find pay load limit. You and I are Southern Californians and the great drought is apparently over for now but I've rolled into campgrounds that had water two hours earlier. That would wreck a night's camping if you had dry or nearly dry tanks. The difference? From Frank's song..."Night and day..."
  • One is a truck...other a car...both "can" tow that trailer...one will do it better and last longer doing that
    One can MANHANDLE the situation better than the other when Mr Murphy crosses your path
    I own an Odyssey and several trucks, knew the difference long ago before buying the van...this is like trying to explain sex to a virgin...but you already answered your own question...
    rpodcamper wrote:
    Hi Everyone,
    Thanks in advance.
