Only_True_Mosno's avatar
Apr 23, 2017
Ford F250 ? F350? Or GMC 3500?
I am looking at a Montana 3791RD and currently own a Ford F250 that pulls my Cougar 327RES fiver quite well. The Montana sounds like it may be considerably heavier.
So my question..will my F250 be big enough to tow it?
If not I am assuming the F350 or GMC 3500 will be? Which of these two vehicles would you buy?
The weight numbers conversation sounds like a foreign language to me so any expert help would be appreciated. Thanks!
Montana 3791RD
Specifications
Shipping Weight 13470
Carrying Capacity 3475
Hitch 2945
Length* 41' 1"
Height 13' 5"
Tire Size ST235/80R16E
  • Trading for a SRW 350/3500 is pointless - you could make your 250/2500 the same truck for a lot less money. Might even be the same truck already. The gasser is really going to struggle and you can't fix that, though - I think it's dually time if you want to go that big.
  • blofgren wrote:
    I'm assuming that the pin weight advertised is for an empty unit?
    If so I would bet that you will be looking at 4k lbs plus loaded pin weight just like our fiver is. Realistically, you are looking at a 350/3500 dually in order to stay within all of the truck's ratings. You will get all kinds of information that a 350/3500 SRW truck will be fine to pull that trailer but you will likely be over the truck's GVWR and possibly rear axle/tire ratings.
    Personally I would never want to tow my fiver with a SRW truck but I prefer to stay within all of the truck's ratings.
    In regards to brand, there is so much childish banter on here that I won't offer anything other than drive all 3 and pick which one you like best. Or more importantly, the one that your wife likes best! ;)
    X2 ^^. Our fifth wheel isn't as heavy as yours (3,100 lbs. pin weight loaded) and we were at the max load ratings for the rear axle of a 2013 3/4 ton truck (and ratings have increased over the years). We traded for a 1 ton DRW truck and it made all the difference in the world. Not only are we well under the load ratings for the truck, but the rig is much more stable under all circumstances. My stress level towing is also about 90% lower...
    Rob
  • Ivylog's avatar
    Ivylog
    Explorer III
    You are asking for trouble. Your truck is barely capable and the E rated tires on the trailer are only good enough for the dry weight of the trailer.
  • I'm assuming that the pin weight advertised is for an empty unit?
