notsobigjoe
Jun 28, 2022Nomad III
ticki2 wrote:
You can also use an old style belly bar if it doesn’t interfere with anything under the frame like exhaust or drive shaft . Given you use the right size material they are very strong . The down side is they are always there sticking out . You can make them short and use removable inserts . Keep in mind that with either Torklift or belly bar you are more likely to rip out the attachment on the camper long before either of them fail .
Yeah, since the conversation has already taken a turn I'll jump in. Belly bar, 25 bucks, welder 50 bucks, hardware 30 bucks, fast guns were the expensive part. Been that way since 2009. Everything from Torklift is overpriced because they own the market.
