BenK
Jun 30, 2018Explorer
Less...went back to this mornings news readings...
This is what am talking about ONLY and OEM can do the right stuff to the whole engine design...3rd parties can NOT afford to cast a new engine block, heads, etc, etc...
2019 Chevrolet Corvette ZR1 First Test: Out With a Bang
Notice the references to 'heat'...a major issue when stuffing or force feeding any ICE. The bigger the block...the more heat rejection surface area.
and
Boils down to BTU density, thermal mass' ability to move that heat and the ancillary stuff that goes with this common issue...thermal management and the designed in safeties that are mostly based on thermal metrics
And towing heavy is way harder than any sports car, drag racer, etc...as how long do they stay WOT at GVWR & GCWR ??? Add in on inclines 'some times' to 'often'...
which is notoriously prone to power-sapping engine-protection mode due to excess heat
and
and there are four new heat exchangers (13 “radiators” in total) tucked hither and thither
44,071 PostsLatest Activity: Aug 16, 2026
