esfd243's avatar
esfd243
ford factory 5th wheel prep
We are looking at new Ford trucks and some I see with the 5th wheel prep package. Dealer tells me they are only compatible with the Reese Elite series hitch. Does anyone have a pic of their truck with this set up? Im not sure if I am picturing this correctly or not.
  • ljr wrote:
    I have a Trailersaver with the Ford factory prep.
    Do you? Or is it setting on an adapter?
  • 4x4ord's avatar
    4x4ord
    Explorer III
    You can buy the puck system through parts and add it on a truck that was ordered without it but I believe it is a little more money that way.
  • ^^^^ is right. If ordering, get the 5th wheel prep pkg and factory puck system. If memory serves me right, I think the puck system was developed by Reese for Ford and Ford was 1st to offer it. As for having to by a Reese hitch only, BS. Buy one that's been mentioned above.
  • Reese has a picture frame adapter that allows you to use any hitch that fits in standard bed rails. I got one for my Trailer Saver air ride hitch and it works fine. The down side is it does add about 2" of height to the hitch. I was able to lower my hitch height about an inch and a half so it was pretty much a wash for me.
  • Clicky If you buying the truck new this seems like the way to go. Other wise you then have to do something else that will cost as much or more.
  • esfd243 wrote:
    So this does not require rails? and you cap the holes in the bed when you take the hitch out?
    Yes.
  • I have a Trailersaver with the Ford factory prep.
  • So this does not require rails? and you cap the holes in the bed when you take the hitch out?
  • Dealer is wrong, or just wants you to buy from him. There are several manufacturers that make hitches to fit the Ford prep. I have the Reese Elite and like it. But Pullrite, B&W, Curt, and I think others also have them.
    I like the Reese Elite as I often haul 8' pieces of lumber and can slide a number of them under the hitch to lay flat.
    B&W makes a hitch that fits in the factory Ford Hitch Prep, and I believe Curt does also. There are probably others but I don't know what they are.
    Rich
