OkieGene's avatar
OkieGene
Ford Fuel Mileage?
The window stickers don't list the fuel mileage.
I'm considering a brand new 2017 to 2018 "Work Truck" Ford F-250 Super Duty with the V10 engine and auto trans.
( The work truck series costs a LOT less than the regular line. I can get one out the door from $37,377 and up. Retiring soon, won't make payments, paying cash, won't break my bank account. I won't spend $60-70 Grand for a truck when I'll only tow the trailer 2 or 3 hours a day.)
I'm guessing it will probably deliver 9-10 MPG, and I'm guessing it won't make much difference between towing roughly 7,500 lbs. of no load at all. I have the monthly budget to afford all the gas I want but just wanted to know MPG.
Thanks
  • Hi... I would suggest a diesel over a gas engine for towing .... much better power ... lower fuel cost. Jim2007.
  • Window stickers stating fuel mileage aren't required on real trucks, only the "1/2" ton models.
    Diesel will do about 20 to 30 percent better than gasoline, so you make the decision that fits your situation. You will hear all kinds of accurate and wildly stated mileage figures, so you can't base a decision on that.
  • patperry2766 wrote:
    V-10 isn't an option in the F250/350 line. Only the 6.2L V-8 & 6.7L diesel.
    6.8L V10 can still be had in the chassis cabs.
    I cannot speak to mileage with the V10, but my 2017 F250 with the 6.7 has averaged 16.8 since new (nearly all uploaded since we bought in late fall, and have not been out with the trailer this spring) according to the computer, and is often in the low 20's at 70 MPH, between regeneration of the DPF. Those unfortunately bring a tank average back to above 16.5 - 17 range.
    With the V10, I suspect you will be lower in the normal highway cruising, but you will not suffer the 10 MPG regens either.
  • V-10 isn't an option in the F250/350 line. Only the 6.2L V-8 & 6.7L diesel.
