austinjenna
Jul 21, 2017Explorer
This isnt true. I had an 06. I had bad vacuum lines to the front, but it would still go into low. Basically it have me a 2wd low. I used this so the time backing my camper up a hill into my driveway. I never fixed mine on purpose. The vacuum lines up front are a common problem. Next time you put in in 4wd turn the fan up and see if it switched to defrost. This would indicate a vacuum leak.
Did that trick as well right off the bat, it does not go to defreost
44,027 PostsLatest Activity: Mar 05, 2025
