Grit_dog
Jun 10, 2019Trailblazer
Ford Triton Engine Spark Plugs PSA
While Ford is well known for spitting spark plugs, the ones that don't are the ones that tend to break on removal.
04-08 I believe, the super long 2 piece sparkplugs were used in the 3V heads (maybe others).
Having just bought a Mustang GT that is a sticker, not a spitter, I decided to change plugs now with low miles (35kmiles) than procrastinate.
Got all of them out no problem, no oil needed, but even at such low miles on a car that is basically in new condition, every plug was very corroded in the hole and required working back and forth a bit and they all squealed the whole way out.
If you have one of these, the plugs rusting (no carbon on mine, just rust) in is a real concern. Assuming a linear rate of corrosion or carbon vs hours/miles, and how hard these were to remove, I'd estimate by 100k miles, you have a 100% chance of breaking some unless you spend the time and work and lube them, which takes days, not hours.
