Cummins12V98
Jul 13, 2022Explorer III
cummins2014 wrote:Cummins12V98 wrote:
Someone has their head stuck Ford's AZZ. WHY????? would the numbers posted FIRST in big bold print comparing all three show RAM's standard output numbers in stead to their HO with AISIN numbers??? Oh sure they mentioned the HO later in passing.
Example........."This is where it happened. A 2020 Super Duty laid down 498 hp and 1,086 lb-ft of torque on these rollers—effectively leaving the Duramax-powered ’20 GM and Cummins-equipped ’21 Ram that were also tested here at the same time in the dust."
Reading the above is a SKEWED paragraph made to have Ford look better.
YES the Ford does put down what they advertise, NOT doubting that just don't like these type of fan based articles no matter the results.
You don't like it because you are a Ram fan ,if it was reversed it would be thumbs up. Live with it .I can say the same thing about someones head stuck up a Rams AZZ .
I have two sons both with new 2022 trucks ,they are impressive. From what my ford owner son tells me that Ford is pretty impressive towing his new fifth wheel . I have driven both, I would buy either one .
Same response, nice "bait" not going to bite!!!
