ib516's avatar
ib516
Explorer II
Jul 28, 2014
Ford vs Ram
Ford and Ram are arguing over who has the best in class numbers between the F450 and the Ram 3500. Some things that stood out to me from the article:
Ford doesn't comply with SAE J2807
"Ram says its vehicle follows the Society of Automotive Engineers' J2807 guidelines (an agreed upon list of standards for verifying towing capacity created by representatives from each truckmaker and towing industry professionals), while Ford says it will officially adopt the SAE guidelines when the Super Duty's new platform arrives, likely in 2016. Ram was quick to point out that means Ford is using its own methods to determine towing capacity, and those methods may or may not follow the SAE standards."
Ford uses some creative methods for calculating "max payload"
"Much of the argument in this towing war of words hinges on the the fact that both the Ram 3500 and Ford F-450 have an official gross vehicle weight rating — a factor used by most pickup truck users to determine work capability — of 14,000 pounds. However, according to Automotive News, when adding the F-450's curb weight and max payload capacity, its GVWR total is 14,061 pounds, which would officially put the F-450 into a different weight class and make its "best-in-class" claim something of a misnomer.
So the methods Ford uses to determine its maximum payload number could be seen by some as less than fair. It's worth noting that the debate about max payload numbers has a long history, with Ford still using very questionable practices. For example, Ford typically uses stripped models to get the highest max payload number possible. That means for a given vehicle's stated curb weight number, it is quite likely it was achieved by removing the spare tire, the interior seats, the radio or navigation system, and very likely the jack and center console as well. One ounce of truck removed, of course, means one more ounce of carrying capacity can be added to that model. Ethical? Probably not. But against the rules? No.
GM and Ram (and Toyota and Nissan for that matter) do not go to the lengths detailed by Automotive News that Ford does, but that could change if there isn't some kind of agreed-upon standard for calculating those numbers. In the meantime, we don't expect this to be settled soon. It wouldn't surprise us if both the Ram 3500 and Ford F-450 ran commercials stating they both lead the segment in max towing."
LINK to story
