skipnchar
Jun 16, 2014Explorer
It's possible you're just out of range or that the antennae is not correctly AIMED to pick up a signal. I assume you have tried very slowly rotating the antennae and with each movement search of a signal from known channels in your area. Digital signals do not have the range of analog television but if you get any picture at all it should be a perfect one (no more snowy edge of reception stations). Also be sure your TV is set up receive the input from the correct source and let the TV search all available channels.
Good luck / Skip
Good luck / Skip
44,056 PostsLatest Activity: Jan 12, 2020
