old_idaho_guy
Aug 16, 2016Explorer
I've found that if you put some boards or other blocks under the stabilizers so they are not extended completely there is less movement. Also some screw chocks in between the wheels helps also. I still like not having to manually lower the stab's, but then I'm an old Idaho guy.
