- CalicajunExplorerNice tip for finding leaks. Thanks for posting.
- rbrummExplorerBeen fighting it for a while. The window isn't installed in the opening very well, in fact I should push it out and reset it, but the Proflex will work for now! Had my daughter run the garden hose and I could watch the water run in so I know that it is fixed until next time.
- RedRocket204Explorer
BTPO1 wrote:
Interesting pressure test method, but it obviously works. Glad you were able to find your leak.
Props for creativity for an isolated area! - BTPO1ExplorerInteresting pressure test method, but it obviously works. Glad you were able to find your leak.
- OasisbobExplorerGood job finding the leak. Sad you had to go through this. Where is the quality? Sheesh
44,065 PostsLatest Activity: Apr 12, 2026
