mtofell1
Nov 17, 2015Explorer
LIKE2BUILD wrote:
I need to clarify a bit. He doesn't intend to use the trailer year round. The main thing is he wants a TT that is capable of handling temperatures around freezing. Basically he's wanting to use into the November hunting seasons in WI then winterize and shut it down until spring.
Staying in one spot to replace a cabin? A park model TT would be good but how about a basic manufactured home? Depending on the area, a manufactured home can be set down very easily. This would have insulation, plumbing, electrical, etc. like a new house. This would be a great transition from an old cabin IMO.
A lot depends on how the home/trailer is to be used. If it's just to be setup in one spot on a semi-permanent or permanent basis a TT is not ideal. Go for a park model or manf. home. You will likely gain energy efficiency and overall livability with each level you go up.
