Gjac wrote:
I have read on here about frames welds cracking and axles bending. Are these problems basically with longer heavier TT's driven on bad roads or is this prevalent with short TT's, 18-22ft 3500 lbs or less UW also?
I can't find any info on frame thickness or material on MFG web sites. I would think that the frame thickness would be the same on a 22 ft vs a 27 ft TT, making the frames stronger on shorter TT's, but that is just a guess.
Also I see where Winnebago uses huck bolts instead of welds to attach frame structures together is this process better than welds?
Bending and cracking of travel trailer frames is real. It may not happen a lot, but it is real. I have had to deal with 5,000# to 10,000# GVWR rated campers which had frame cracks/failures.
The weight itself is not the issue, the reality of what you are buying and how it is made, is the issue.
You seem to be talking about a TT with a single axle in the weight range of 3,500#. Again, weight in this case is lower and the frames are made lighter and thinner. The end result is, the frame needs to be made strong enough for what the load is to be and where you load cargo/water. You have some level of control where cargo is placed. Left to right loading in the camper is determined by how the floor plan is, and where you can place items. Soon after you load the camper, weigh the camper to get a total axle weight, then weigh each wheel. Do not overload one side of the camper, each side needs to be at or less then the allowable axle weight rating GAWR. You may find, you are under the total weight but over on one side.
The comment about the use of axles/tires and wheels being installed less then the total GVWR, is also real. Not all brands do this, but it can be common in lower priced campers. I myself will not buy a camper where the sum of the axle GAWR is less then total GVWR. There is very little safety margin in these cases for off center loading. And you can have lower cargo capacity, yet a very long camper.
The huck bolts are not a problem if used and size right. They act like rivets of years ago. In thinners frames, the Huck bolt can reduce weld stress and welder error.
A welded frame, designed right, welded right, is not a problem.
As others have said, the RV industry is looking to save weight and taking it out of the steel frame is an easy choice. This does not matter what size or weight range. Cost to produce also comes into the equation.
The 22ft verse 27 ft frame, this depends. Some manufactures put tandem axles on both a 22 and 27 ft frame. Now a days, a 22 ft an be on single axle and very low cargo capacity. There is no rule of thumb on length and frame strength that fits modern day campers.
When the use of a weight distribution hitch is needed, that creates other stress issue in trailer frames, mainly the A frame and header area. Do not oversize the WD bars, make sure the dealer and the manufacture (especially them) will warrant the frame when a WD hitch is used, and what is the max WD bar they will allow? If they tell you, they will now allow a WD hitch, and your tow vehicle cannot handle the weight without one, well, now you know going into the sale, you have a problem to start with.
Hope this helps.
John
