- _1nobbyExplorerWithout pics....I have no idea what you are talking about.
- bigbullelkExplorerbump it up. would like to hear some more opinions, pros, cons, etc.
- Ron3rdExplorer IIIDon't know if there is any advantage to the frameless, but the wife likes the looks of them so that's what we have.
- wincrasher65ExplorerThey are fine for a summer use trailer. Not for a 4 season.
The dual pane in the frameless is not a very good dual pane - basically they are two thin sheets of glass bonded together - so very little thermal benefit.
The framed type of dual pane generally have a thicker glass and there is a gap between the panes giving you good thermal performance.
The frameless also have rubber seals that the glass is pressed against. Not as tight a seal as you get in the framed type. So long term, the framed will probably suffer from fewer leaks. - Doug33Explorercan someone post photos of what the two types look like? I'm pretty sure I have framed windows, so I'm not sure what a frameless window looks like.
- LantleyNomadI have frameless and have no issues however I do think framed windows provide better airflow.
In the end I like the look and simplicity of frameless - edatlantaExplorer IIAnother thought on frameless windows if you are talking dual pane.
I have dual pane windows with frames and when they start to leak moisture between the panes, and they all will over time, it is time for repair or replacement. I recently had mine repaired in Florida and I'm sure glad I had frames. The repair cost was $225.00/window, but it is $450.00/window if they are frameless. A new large window is almost $1,000.00 new so obviously repair is a better deal and with a better warranty also.
Just more food for thought. - BurbManExplorer IIII like the look of frameless, but really like the double-glazed tinted windows we have now even though they have frames. I would only go frameless if they were double pane like we have now.
- edbehnkeExplorer IIpick the trailer and don't let the windows limit your choice.
i don't like the frameless windows because of air flow but they are neater looking and I have a/c, 2 of them so there you go. - hbillsmithExplorerI've had both. We liked frameless because we could leave them open in a gentle rain. We liked the framed ones because they would slide all the way back and let more of the outside in. We experienced a minor leak issue (easily resolved by the way) on both types, so we think that's a tie. Our framed had less tint than our frameless and in the hot Texas sun it made a difference. This time we have tinted framed so for us that's not an issue.
Just go to a show or walk around a camp ground and chat.
Oh and lastly, style. The frameless do look neater ;-)
44,067 PostsLatest Activity: Jun 03, 2026
