BurbMan
Mar 19, 2019Explorer III
Kayteg, that piece of steel is missing, I think what I'll do is add a piece of angle iron to reinforce the vertical section temporarily. I agree the best fix is a continuous steel corner that I'll have to fab when I do the repairs.
Photomike, I was also thinking of a 4x4 underneath the front of the basement with a bottle jack on each side. The issue is I have to raise it and support it while I remove the blocks from underneath and get the vehicle under there.
I looked at the U-Haul double axle utility trailer I was thinking of using, but the sides are 32" high, so I would need to add lots of blocking in the bed for the camper to fit....not ideal. I looked at their pickups, but they only rent 1/2 tons.
Do you think this truck from Home Depot would work? They are 250's with a stated 4,000 lb load capacity, which is plenty.
The height is about where the camper is sitting now so should go on easily. A couple of big ratchet straps over the top? It's exactly 3.0 miles down a local road from the storage yard where the camper is to my house.
44,068 PostsLatest Activity: Jun 10, 2026
