Photomike
Mar 19, 2019Explorer III
BurbMan wrote:
Kayteg, that piece of steel is missing, I think what I'll do is add a piece of angle iron to reinforce the vertical section temporarily. I agree the best fix is a continuous steel corner that I'll have to fab when I do the repairs.
Photomike, I was also thinking of a 4x4 underneath the front of the basement with a bottle jack on each side. The issue is I have to raise it and support it while I remove the blocks from underneath and get the vehicle under there.
I looked at the U-Haul double axle utility trailer I was thinking of using, but the sides are 32" high, so I would need to add lots of blocking in the bed for the camper to fit....not ideal. I looked at their pickups, but they only rent 1/2 tons.
Do you think this truck from Home Depot would work? They are 250's with a stated 4,000 lb load capacity, which is plenty.
The height is about where the camper is sitting now so should go on easily. A couple of big ratchet straps over the top? It's exactly 3.0 miles down a local road from the storage yard where the camper is to my house.
Why not a couple 4x6 / 6x6 or whatever running front to back on both sides. You don't have wheel wells to worry about on that truck. A couple 2x6 / 2x8 on the bottom and same running across the front. Then add a couple C clamps or even some strapping at each jack to stop the lacks from bending out. Screw it altogether till you get it home.
As for the truck people put pallets of bricks and bags upon bags of sand/ cement/ etc in them and drive down freeways. I am sure a slow trip 3 mile is never going to do any damage.
44,068 PostsLatest Activity: Jun 10, 2026
