ticki2
Mar 19, 2019Explorer
Kayteg1 wrote:If you have found any documentation for the above I would be interested in reading it . I looked into it a few years ago but was not successful .
You might be facing some legal issues with rental truck, but when you read about tires - they can hold up to 3 times rated load, when rolling.
It is heat generated with speed that makes the bonding to come apart.
Meaning even if you load double the rated weight- the tire will hold 30 mph speed on cold day. Just inflate the tires to max on sidewall.
Good luck with moving.
44,068 PostsLatest Activity: Jun 10, 2026
