BurbMan
Mar 24, 2019Explorer III
Well it was a nice sunny day here on Long Island and a great day to move a camper! The jacks held, my ratchet strap around the tree kept it from toppling over and all in all was a good day.
Kayteg, I think you are right about the bracket, I was cranking the jacks by hand and there was no binding, so the jack tubes must be straight.
You can see the green ratchet strap in this pic going over to the tree. Also hard to tell but they spread a bunch of asphalt around in the yard since the camper was parked, and there was a big mound in front of the camper. I had to dig down to re-level the ground so the truck would go under the camper.
Not a lot of room here since the camper shifted over when I was jacking it. had just enough room to get the truck in there.
I was tempted to run over to the local county park CG just to see what kind of comments I would get!
Fun fact, these HD rental trucks had load sensors built in and it blares the horn if you exceed the 3000 stated load limit. The "as manufactired" stcker on the camper is 3017 and I was fine until I sat in the drivers seat LOL. Interestingly enough, this overweight alarm blares with the key in or out, motor running or off. The only time it shuts off is when you put the truck in gear....
I set it up behind the garage at home, and dropped it down low so it would be easier to work on. The weight is being carried by the 2x10s and cinder blocks, minimal on the jacks.
I since turned two of the 4 block stacks 90* to give it more front/rear stability
Tarped to keep any more water damage at bay. You can see the block stack turned in this pic, I also turned the one caddy corner in the rear.
I'm smack dab in the middle of a major kitchen remodel so this is gonna sit until I get some time to look at it. I'll be poking around here asking questions as I learn all about TCs...debating whether to sell the TT this season or wait until next.
44,071 PostsLatest Activity: Aug 30, 2026
