4x4ord
Mar 19, 2022Explorer III
alexleblanc wrote:4x4ord wrote:
^^^ Going from a 2017 to a 2022 you're going to find your doppelgänger is not really a doppelgänger. The newer Powerstroke and 10 speed is incredible .... will your '22 have the 3.31 rear gears?
I ordered the 3.55 rear gears not knowing if i really needed them or not.
You might want to consider changing your order to 3.31 gears. My 2021 had 3.31 gears and I was very pleased with its fuel economy. My ‘22 has 3.31 gears as well but I can’t yet comment on its mileage. Unless someone is continually towing a 20,000 lb triple axle toy hauler 3.31 gears are a better choice than 3.55. With 3.31 gears there may be times that you are towing in high winds or up and down hills that you choose to lock out 1 or 2 gears but with a 16,000 lb trailer in tow 3.31 gears will actually out perform 3.55 gears on a 6 or 7% grade. First gear with the new Powerstroke/ten speed and a 3.31 final drive is capable of putting more torque to the rear axle than a 2017 F-450 can in first gear with 4.30 gears.
44,071 PostsLatest Activity: Aug 30, 2026
