PenMan
May 03, 2014Explorer
Could be any of the above answers or a combination of a couple. Make sure the valves are aligned so the pump is drawing from the fresh water tank and not the siphon line (if you have one). Open a cold water valve and run the pump. If you get water from the valve then do each cold water valve and the toilet. Make sure the hot water heater is not bypassed (again if you have it piped with a bypass) and then open a hot water valve and run the pump until water comes out. It takes a while to fill the heater so be patient. Open each hot water valve until water comes out. Now make sure all the valves are shut. If the pump continues to run you need to check for leaks. If no leaks, you probably have a bad pressure switch in the pump discharge and it will need to be repaired/replaced. Hope this helps.
44,056 PostsLatest Activity: Nov 19, 2013
