ssemalone
May 04, 2014Explorer
So being new to this I:m not sure about valve locations and positions...There is a small valve that looks like it isolates the antifreeze line, then there is a larger valve with hot and cold water lines attached to it, the small one has a single handle that turns about a 1/4 turn. the larger is similar to a residential valve under the sink. oval and turns several turns, this one should be aligned with the lines right???? in other words the "points" of the oval handle in line with the hot and cold lines.....
44,056 PostsLatest Activity: Nov 19, 2013
