shasta24 wrote:
40 gallons of fresh water used up in two short days. We are training 2 granddaughters how to conserve from this point on. Do you guys have any suggestions or pictures of what you do to add water to your tank when its dry. We borrowed a 5 gallon bucket and funnel. Didn't work so good. Thanks
wire in a water pump in the pass through next to the inlet. dip tube on the water pump inlet, stick outlet tube into the fresh inlet opening. turn on switch, pump away.
And teach the grandkids etc. conservation. DW and I, daughter, SIL and an 8 and 5 year old grandkids 40 gallons seldom lasts LESS than 2 days, usually 3 full days, and refill sometime day 4
