Lynnmor wrote:
There is no need to buy a pump, switch, wires and a lot of hose. Your trailer came with a pump, just alter the plumbing so that you can pull water in the fresh water inlet and send it to the tank.
And as we've "discussed" before, perhaps you should also mentioned this means also having to fool around with switching valves each time you want to use that one pump for water transfer, during which time the water system can't be used by anyone else for it's normal purpose. To each his / her own but I'll say "Thanks, but no thanks". :W
