ER_Alaska's avatar
ER_Alaska
Fresh water tank drain valve issue
The handle on the plastic drain valve broke, so I need to replace the valve. I removed the two screws from the valve and pulled the valve out from the tank about half an inch. I can see there is tubing connected to the back side of the valve and I should be able to pull it out enough to replace the valve but the tubing is hanging up on the hole cutout of the tank and if I pull any harder the tubing is going to come off the valve. I can only imagine the impossibility of then trying to fish the tubing out of the tank. Where does the tubing end that's opposite the valve go? I thought that the water would be right on the other side of the valve. I don't know what my next step would be if the tubing disappeared into the tank. Just to note, the tank is on the underside of the trailer and can be seen when looking under the forward end of the trailer. The valve is on the forward wall of the tank and can readily be accessed from underneath the trailer. Oh, and I never had issues with the drain handle when I lived in Alaska but found when I moved to NC that everything seems to get soft from the heat...Thanks.
