cruzbill
Feb 23, 2015Explorer
Your trailer should (must) have a check valve at the city (campground) water inlet, its there to prevent your pump from pushing water out thru the city water inlet. The check valve only allows city water in, not fresh tank water to be pumped out. Easiest way to think about it is this: if you have your pump on, you are drawing water from your fresh water tank; if your pump is off and you still have water at your faucets, you are connected to city water and your fresh tank is not being used. Sanitize your tank (follow your owners manual) before you use it.
44,025 PostsLatest Activity: Feb 18, 2025
