fallsrider
Feb 23, 2015Explorer
mdamerell wrote:
May not be that simple. If the water pressure is higher in the CG, your pump will not turn on unless you shut off the city water. Plus you'd have to flush the lines to clear the "city water".
We normally run off city water and use bottled water for coffee and drinking. If the city water pressure is low, we will fill our FW tank and use the pump to get a better shower pressure. If the forecast calls for freezing weather we will unhook the city water and run off the FW tank. Also keep some water in FW tank to flush toilets when we travel. Don't like public restrooms.
Exactly. Most likely the pump will never come on.
We have a 2 gallon container and a 6 gallon container for coffee/fresh water, depending on the length of trip. We bring water from the tap at home.
44,025 PostsLatest Activity: Feb 18, 2025
