ZeeLet50's avatar
ZeeLet50
fresh water tank replacement
In the middle of doing this and having a difficult time getting the old sensors off the tank. i thought I would just loosen the nut and pull it out but its not cooperating. am I missing something? Any help appreciated.
  • UPDATE Ok, using much more pulling force than I thought it would need, they all came out. Thanks for the help.
  • Is there a big enough opening that the sensors are installed from inside the tank?
  • Got the wire off but pulling the sensor back through is not working. looked up new sensors and they are plugs per say. So alittle more prying and if they dont come out, will buy new ones.
  • They probably used some sort of sealant. Try a hair dryer to see if warming helps.
    Bill
