MuddyLane
May 30, 2013Explorer
With regards to winterizing your trailer and adding antifreeze to your fresh water tank that this is not a recommended practice. The best way to winterize is to get a hose from the dealer and connect directly to the pumep to push the antifreeze into the lines and then just drain the tank. Alot of trailers have an isolation valve by the pump to connect the hose to and you can pump right from the jug of antifreeze.
