Lynnmor
Mar 24, 2014Explorer II
oldcat1 wrote:
My pump supply is also on the side of the tank. It is about 3" above the bottom of the tank. I have almost 20 gallons left in a 46 gallon tank when pump sucks air...crazy! Of course I want to do this mod. So my question to 4jeeperz, choochooman74, and any others who have done it, is have you had any problems with sucking sediment into your pump. I do have a screen type filter on my pump.
That is a possibility, but I have had no problem. When you have the bottom fitting open, flush the heck out of it. I use the supply hose as a pressure fill hose so that back flushes it from near the filter back to the tank. Just keep an eye on the filter screen.
I also had wasted water capacity from the tank sagging between the three straps holding it up. I added two more straps to reduce the sagging.
