snwbdr94
Apr 11, 2018Explorer
Freshwater line gummy
I've been working on rehabbing an older sun lite TC and looking at the plumbing I noticed the 3/8 clear tubing line from the tank to sink is dark and gummy. I cut off a small section to test a strong bleach mix and I would say it removed 85% of the gunk but still left behind a pinkish slime in the clear tubing that wouldnt rinse out. If access was easier I would just replace the entire section but it looks as if it runs behind the refrigerator and under. The hole it runs through was sealed by some white hardened rubber preventing it from being pulled through. My guess is I will have to remove the refrigerator and replace the line but I'm hoping someone has another magical solution. Side notes, the 1.3gpm water pump was seized and water tank looked clean. I will bleach the tank to sanitize it.
