snwbdr94's avatar
snwbdr94
Freshwater line gummy
I've been working on rehabbing an older sun lite TC and looking at the plumbing I noticed the 3/8 clear tubing line from the tank to sink is dark and gummy. I cut off a small section to test a strong bleach mix and I would say it removed 85% of the gunk but still left behind a pinkish slime in the clear tubing that wouldnt rinse out. If access was easier I would just replace the entire section but it looks as if it runs behind the refrigerator and under. The hole it runs through was sealed by some white hardened rubber preventing it from being pulled through. My guess is I will have to remove the refrigerator and replace the line but I'm hoping someone has another magical solution. Side notes, the 1.3gpm water pump was seized and water tank looked clean. I will bleach the tank to sanitize it.
  • It would be better to replace the tubing .Most campers have an outside louvered access door to the back of the frig . Do you not have one? Can you remove the hard rubber seal to free up the tube ? If you can , attach a string to the old tube before pulling it out to use as a pull line for the new tube .
  • It sound like the water line is not extremely long, especially being in a Truck Camper. So... any possibility of just running a semi-stiff bare wire through the pipe and let the wire break free the accumulated gunk? Kind of like running a cleaning rod down the barrel of a shot gut. In other words, snake it out? Perhaps the wire would break some of the gunk up, it might be enough to free up the remaining slime and it can be flushed out then. Maybe someone will come up with a better solution. This is just my initial thought and probably something I'd try first, before ripping the plumbing out and dismantling RV appliances.
    Edit:
    Another idea just hit me.
    You know, automatic dish washing liquid cleans dishes, lime, water spots, grease and a bunch of gunk from dishes, right? Maybe a strong automatic dish washing liquid solution poured through the pipes and then a good flushing afterwards might clean it up too. Here again, it's worth an attempt before dismantling the camper.
