brulaz's avatar
brulaz
Friction Sway Bar Adjustment?
For those of you with a separate Friction Sway Bar, how do you adjust it? The instructions that came with mine are pretty vague.
The bar has a little lever at the top and a bolt at the bottom. So while the lever is loose, I hand tighten the bottom bolt as far as it will go. Then crank down on the top lever as far as I can, leaving the lever horizontal.
The thing creaks and moans when making sharper turns, and really does seem to help with cross winds (the whole rig seems to move, not just the trailer!), so I guess it's working as advertised.
But curious if this is what I should be doing ...
