LarryJM wrote:
Terryallan wrote:
As for removing. Remember. Any thing less than fully on, is off.
Sorry, but that tells me you don't have much if any experience with this type of system. What is called the on - off bar is there to fully set the system on a consistent basis whatever sway mitigation you have after adjusting the tension nut. It is not really like an on or off switch. Partial tightening is like riding or dragging your brakes ... thus this concept of fully on or fully off is a misconception and not supported by the directions from the manufacturer on what to do in adverse road conditions.
Larry
From Reese. Instructions for sway control bar.
NO3. The handle is an On/off devise. The bolt below (7)is for adjustment only.
No4. When towing in slippery conditions such as wet, icy, or snow covered roads, or on loose gravel. Turn On/off handle counterclockwise until ALL tension is removed from unit. Failure to do so could prevent tow vehicle from turning properly.
So you don't need to argue with me. You need to argue with Reese. Me? I'm with them. Maybe it's not me who doesn't understand the unit.
Clearly. A TT should not sway without a sway bar, as you aren't supposed to use it in slippery conditions.
