thehippie's avatar
thehippie
sway control friction bar
This is how i did with my sway control bar.
I remove the hand crank handle and replace it with bolt and nut.
I tighten both bolt using 300 ft lb torque Ryobi impact wrench.
It's as tight as a virgin.
  • thehippie wrote:
    old guy wrote:
    If I am wrong it wouldn't be the first time but I think the instructions say not to over tighten. 300 ft lb might be over kill
    i know
    but so far so good,
    i didn't wobble in AZ unlike B4
    You do know the bolt / handle is not the friction adjusting bolt. It is only the on / off "switch" tight is on, loose is off.
    The adjusting bolt is the bottom one. Tighten the top all you want. It won't make much difference. Tighten the bottom one, and it won't ever move.
    Also. You do know that if you get it too tight, It can prevent the TV from turning correctly, and prevent the Tt from full straightening out after a turn. so that it will always feel like the TV is trying to turn. This can be very dangerous, especially in the rain, and is why instructions tell you to remove it in wet conditions.
    In truth. If your trailer "wobbles" with out the sway bar. You have other problems, that the sway control is only hiding. Fix your sway problem BEFORE you install sway control. A trailer that has to have sway control just to drive in a straight line, is a trailer just looking for a ditch to run into.
    i know
    but so far so good,
  • If I am wrong it wouldn't be the first time but I think the instructions say not to over tighten. 300 ft lb might be over kill
    I sure hope you aren't recommending this nonsense.
    nope
