12rvjoe wrote:
Interesting .... I have been using mine wrong all along lol
Question's : How do I know that I have adjusted the tension bolt correctly ?
: When I turn the top handle to off ( loosen it ) the bar slides easily, should it ?
Joe
When I loosen the top lever, the bar slides easily. I think that's as it should be. And then you crank down the lever as much as you can to "turn on" the sway control, leaving the lever in a horizontal position so it doesn't interfere with your WDH.
As for the tension bolt adjustment: trial and error seems to be the answer. On mine, finger tightening seems about right.
