Larryzv7's avatar
Larryzv7
Friction Sway Bar
What is your opinion on having two friction sway bars, one on each side of your weight distribution hitch? I talked to a Camping World repair person who had never heard of two friction sway bars on a trailer while towing. But when I chat with someone from etrailer they advised that any trailer over 25 ft. might need two sway bars. I already use a weight distribution hitch and one friction sway bar but I still have a little bit of sway when towing my 2018 32-ft. Heartland.
I traded in my fifth wheel, which was very easy on towing and did not need a sway bar or a weight distribution hitch. But I’m thinking I want to put a second sway bar on my travel trailer. I understand that a number of factors can create sway, how your trailer is loaded, whether the distribution hitch is functioning properly, etc. I guess what I am asking is do any of you use two friction sway bars, and if so, does it work better than just having one?
An additional question is how much do you tighten your friction sway bar? Camping World told me to tighten it as tight as possible while online instructions say leave some play in the friction plate. I know I have to disconnect the sway bar when backing up but I’m not sure how tight I should make it.
Thanks in advance for your assistance.
  • I agree with DTR, there are better systems out there. I have a Reese Dual Cam and it works great but there are even newer designs that are very interesting and that don't use friction bars.
  • I have a 35 ft trailer and I use an equalizer 4 point hitch with it and have no sway problem at all. have towed all over the place in all kinds of weather too. I had the sway bar type but the 4 point is far Superior
  • My advice is to talk to someone else at Camping World....because the guy you already talked to is mis-informing you.
    etrailer is a very good source for correct product info...
    You also might want to give up the friction sway bars. There are a number of much better hitches out there now.
