Devocamper's avatar
Devocamper
fridge coolig fan noisy
We are on our first trip with our new host mammoth and loving it adjusting to the downsize from the 35 foot trailer.We are finding that the cooling fan for the fridge is pretty noisy and in the hot weather we are in it runs a lot. I don't think there is anything wrong with the fan it is just a high rpm computer case cooling fan pushing out 75 CFM but when things are quiet it can be annoying. this is the first time we have had a fridge in a slide out all or other trailers had a direct vent to the roof so we have never had to deal with this fan noise. Has anyone come up with a solution I was thinking of mounting two fans with slower rpm and move about the same amount air or a little more but wondered if anyone here had a better idea right now the unit has one 12 volt 92mm 47 sdb (loud)75 cfm fan
Thanks
Mike
  • SidecarFlip wrote:
    Depending on the make of fridge (in my case a Dometic), mine was also noisy for a couple reasons...
    One.. I was a cheap fan. There are quite an array of fans available and Dometic uses the cheapest, sleeve bearing fan available. I would suggest replacing it (as I did) with a FDB (Fluid Dynamic Bearing) fan with a computer designed blade. The FDB fans are silent in operation and a computer designed blade will reduce air flow noise. I picked up a couple on Flea-Bay for 10 bucks each, they make no noise whatsoever. But..
    Two: You need to pay attention to how the fan(s) are mounted. Just like a FW pump thats mounted solidly to the substructure of the camper, the fan will transmit operational noise and the camper fram will amplify it. You need to isolate the fan from transmitting operational noise/vibration to the camper itself.
    I did that by adding rubber grommets to the fan mounts. While it don't dampen everything. between the FDB fan itself and the rubber grommets in the mount, my fan noise is very minimal.
    Personally, I prefer not to hear that noise when I'm sleeping at night. During the day not a big issue but at night, I want quiet. Before the modification (new fan(s) and mounts, I was turning off the fridge at night so I didn't have to listen to the fans.
    Pretty cheap fix really, just takes some time on your part.
    Hey Sidecar thanks and yes the fridge is a dometic with one cheap high rpm fan that runs a lot , the original fan is rated at 75 cfm so I was thinking of putting two 50 cfm lower speed fans in since the bracket is made to mount to 92 mm fans on it , lower speed and a bit more air. I am surprised at how much noise the original fan makes and your right it is a pain at night . I have been researching this since I posted this morning I did not know there were so many types and sizes of these case cooling fans I will defiantly go with the FDB fans , thanks
    Mike
  • Depending on the make of fridge (in my case a Dometic), mine was also noisy for a couple reasons...
