Vintage465
Nov 03, 2017Nomad
Also make sure when leveling you're setting the level on the inside of the freezer. That's where all the action is. Once you know where the "important level" is, then you can set the other levels on your trailer based on that one. Seems like older fridges were more inclined to vapor lock when running off level. And yes, front to back was more finicky than side to side. When I worked at my dad's RV shop we would take out at least one unit a month, turn it over on it's head for 24 hrs. Then fire it up on gas to make sure it worked before re-installing it. It does seem like the newer units just get damaged and not locked up like the oldies.
