- goducks10Explorer
MFL wrote:
I think mostly cosmetic, as most front caps do not have a lot of insulation. I do think that the newer front caps are a little more streamlined, which has to help. My FW has something of a bullet shaped nose cap, that seems to help with MPG, comparing to previous one that was lighter, but more square.
Jerry
I would think the insulation is as good or better than the typical.
How do you figure they don't have as much insulation? - downtheroadExplorerArctic Fox is putting a nice front cap on their newer models...
They also have applied or sprayed a protective on the lower half....something very similar to the LineX bed liner material...
This isn't our trailer or model, but we have the same front cap on ours.
- camp-n-familyExplorerNo real benefit other than it's easier to shape for esthetics and aerodynamics. Nothing but air between it and the inside wall.
- MFLNomad III think mostly cosmetic, as most front caps do not have a lot of insulation. I do think that the newer front caps are a little more streamlined, which has to help. My FW has something of a bullet shaped nose cap, that seems to help with MPG, comparing to previous one that was lighter, but more square.
Jerry - coolbreeze01ExplorerSure looks better than the pressed cardboard Filon stuff that too many have.
Done properly, the FG should hold up better.
44,052 PostsLatest Activity: Oct 29, 2025
