Lynnsr
Mar 15, 2013Explorer
dennis1 wrote:
Lynnsr,
If I understand this right then the receiver tube needs to have a little curve to fit. The tube can't be flat. Is that why you cut the piece out so you could bend it easier? THanks,.
Hi Dinnis1
Take a look at your tow hooks when you remove them and you will see that they are placed at an angle so they miss the 3 inch crossmember of the frame.
My receiver was cut so it would simply fit in that space. (No bending involved).
If you pull your tow hook I think you'll see what I'm talking about.
I'm not sure about yours, but on the 3500 in the same year as mine (2003) the frame is identical, as are the tow hooks.
Lynnsr
44,071 PostsLatest Activity: Aug 30, 2026
