Slownsy
Oct 19, 2020Explorer
Front hitch
We have a 2015 F350 4x4 and am considering getting a front hitch what are you yours and why prefer it op as high as possible for when in the dirt. Suggestions please.
Frank.
Frank.
Slownsy wrote:
Looks like I may have to have something made op. As the of the rack only allows 9000lb pull and I intend to use a 17000lb winch. Thinking side brackets 1/4” thick, 3x3” 1/4” wall tube across, With a 2-3” receiver . And make the mound for hitch out of a short section u channel 8”x3” 1/2” thick.
What do you think.
Frank.
What do you think.
Frank.
JRscooby wrote:
Going to use it for a carrier, or to spot your trailer?
If to spot trailer I suggest you mount as close as you can to the right frame rail. Then the driver can at least see past 1 side of trailer.
If a carrier use 1 at each frame rail for a more stable platform.
